close
Transferring number to EE
Gareth43
Problem solver
Problem solver
Hello there I have just activated my sim and filled the form out to transfer my number from giffgaff to EE, now I’m just wondering should I leave my new EE sim in the phone or can I carry on using my old giffgaff one what as my number on it untill the number transfers over ??? Thanks
G Alston
iPhone 17 Pro Max
@Gareth43   You could do both, but keep the EE sim with you as your giffgaff sim should loose signal at some point.  It should take around 24 hours to migrate across.  That doesn’t mean once the giffgaff sim will stop and the EE one will work straight the way.    Once the process starts your giffgaff one will loose signal then it’s a case of waiting for the EE one to work.
