close
Topped up my phone but won't let me make any calls PAYG and tells me to top up.
Brownhill2021
I have just topped up my PAYG Iphone i keep in the car for emergencies, I topped up using the EE site and have my credit card registered but when i try using the phone it says out of credit and i need to top up? it says i have £25.00 of calls credit on the site but cannot get it to work?
Any tips most welcome as whats the use in having an emergency phone if its got no credit?.
@Brownhill2021 : Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
I haven't used the phone for more than 12 months as I live alone out in the wilds, I managed to log into my EE account ok but didn't see anything about hibernation. Do you think i will need to create a new account or will EE be able to reset my existing account? Thank you for your help.
Then it is lost completely. You will need a new SIM with a new number, which you can add to your MyEE.
