close
Timeout on broadband router
RaggedRat
When I plug in my mobile router it switches itself off after a few seconds. Annoyingly takes the time it takes for my computer to boot so by the time the computer tries to connect the router has switched itself off and I have to turn it on again and then tell the computer to reconnect.
Is it possible to either lengthen the inactivity timeout or disable it?
7 REPLIES 7
Jon_K
Former EE Employee
Hi @RaggedRat.
Welcome to the community.
Which mobile WiFi device are you using?
Is it switching off completely or going into power saving mode?
Jon
From the box:
Model: 4GEE Wifi Mini
Type: EE70-sAE8GB3
I'm guessing Power Saving mode as the battery LED is on (constant).
Jon_K
Former EE Employee
Hi @RaggedRat.
Is your WiFi Mini connected to power when this happens?
Jon
Yes, connected to my 12V DC (I live on a narrowboat) via a cigarette lighter to USB adaptor. I know this works as I used the same to charge my 'phone.
Christopher_G
Hi @RaggedRat
Could you try a master reset of the device please?
  1. Remove the bumper to uncover the Reset button.
  2. Using a paperclip or pen, press and hold the Reset button for approxamately 5 seconds.
  3. The device will restart automatically.
Let us know if it works any better.
Reset, re-entered passwords etc. Made no difference. All I want to know is can I disable this? Power saving isn't a problem as a) I always use it plugged in b) I always switch it off when I'm not using it.
Christopher_G
I'm not aware of any way to disable it, @RaggedRat.
