close
Smart router internet dropping
LynnMary
Had smart router fitted on Fibre Max 300. First engineer installed with new master socket. WiFi very week and dropping out. Had 3 further engineers WiFi is very weak. Dropping out now getting impossible  6 times tonight between 6:30 and 9:30pm. May get this finished tried twice, if lucky. Now referred to CAT team. But have to wait 3 days for contact. Please is anyone experiencing this nightmare too. Will try and get out of contract. Accept weak WiFi but cannot continue with internet dropping out so frequently. Using so much data.
@LynnMary : Welcome to EE's Home Broadband Forum.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
LynnMary
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
It's the Broadband going not WiFi.  Goes to flashing orange orange then back to green.
I am expecting call from CAT team on Saturday. I'm not clued up on all the router stats. Just hoped a customer found a fix. If Engineers are struggling I'm probably on the point of trying to get contract cancelled and try another supplier.
Tried moving router, BT fitted and taken away additional modem, new power packs, cables, another router and whatever 4 engineers have tried.
To get the router stats login to your EE Smart Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router.
No other user is able to fix a fault on your specific line, which is what this is.
