close
Does EE do maintenance
Chinock91
Just wondering if EE does maintenance to there braodband every once and a while my broadband router loses internet in the early hours of the morning.
Well, OR does but not every morning & you wouldn't normally even notice it. There's more likely to be a fault on your line.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
