13-06-2021 08:04 AM
Hi
I am not getting the minimum broadband that is in my contract. I am supposed to be getting a minimum fibre download speed of 27.9 Mb/Sec but the BTW Performance Tester is saying it is 2.5Mb/Sec through the wifi (it is the same on other devices)
Here is the technical log:
| Product name | EE Smart Hub |
| Serial number | 2034002368 |
| Firmware version | v0.06.01.08190-EE (Wed Aug 19 18:20:33 2020) |
| Board version | 1 |
| Data sent / received | 119.2 MB / 2.0 GB |
| DSL uptime | 0 days 0 Hours 28 Mins 30 Secs |
| Data rate | 2.68 Mbps/10.83 Mbps |
| Maximum Data rate | 2.8 Mbps/40.6 Mbps |
| Noise margin (up/down) | 6.7/18.4 |
| Line attenuation (up/down) | 31.1/21.6 |
| Signal attenuation (up/down) | 22.0/19.0 |
| Broadband username | |
| 2.4 GHz wireless network name | |
| 2.4 GHz wireless channel | Smart (Channel 6) |
| 5 GHz wireless network name | |
| 5 GHz wireless channel | Smart (Channel 44) |
| Wireless Security | WPA |
| Wireless mode | Mode 1 |
| Firewall | Default |
| MAC address | EC:6C:9A:90:D9:5D |
| Software variant | - |
| Boot loader | 0.0.3-EE (Mon Dec 4 17:32:53 2017) |
Here is the wired speed test results link:
https://www.thinkbroadband.com/speedtest/1623566896399261655
I have tried restarting the router but it hasn't made any difference
13-06-2021 08:14 AM
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, which will enable us to diagnose the problem and advise you further.
1. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
2. What are all the estimates EE gave you when you joined? You'll find them in your MyEE for BB under "My BB Speed".
13-06-2021 08:33 AM
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Handback | WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper | |||
| Threshold(Mbps) | |||||||||
| High | Low | High | Low | ||||||
| 40.7 | 32.2 | 8.8 | 5.4 | 29.2 | Available | Available | -- | |
| 40 | 28.8 | 8.6 | 5 | 24.4 | Available | Available | -- | |
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process | ||||
| FTTP on Demand | 330 | 30 | -- | Available | -- | ||||
ADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | ADSL Availability Date | WBC SOADSL Availability Date | Left in Jumper | |||
| WBC ADSL 2+ | Up to 4.5 | -- | 3 to 7 | Available | Available | Yes | |||
| WBC ADSL2+ Annex M | Up to 4.5 | Up to 0.5 | 3 to 7 | Available | Available | Yes | |||
| ADSL Max | Up to 3.5 | -- | 2.5 to 6.5 | Available | Available | -- | |||
| WBC Fixed Rate | 1 | -- | -- | Available | Available | Yes | |||
| Fixed Rate | 1 | -- | -- | Available | -- | -- | |||
Observed Speeds | VDSL | ADSL | |||||||
| Max Observed Downstream Speed | 11.35 | 14.06 | |||||||
| Max Observed Upstream Speed | 2.6 | 1.26 | |||||||
| Observed Date | 12/06/2021 | 31/12/2020 | |||||||
Other Offerings | Availability Date | ||||||||
| VDSL Multicast | Available | ||||||||
| ADSL Multicast | Available | ||||||||
Premise Environment | Status | ||||||||
| Bridge Tap | N | ||||||||
| VRI | N | ||||||||
| NTE FacePlate | N | ||||||||
| Last Test Date | 01/06/2021 | ||||||||
Exchange Product Restrictions | Status | ||||||||
| FTTP Priority Exchange | N | ||||||||
| WLR Withdrawal | N | ||||||||
| SOADSL Restriction | Y |
Minimum Fibre Download Speed is 27.9 Mb/Sec
Maximum Fibre Download Speed is 36.4 Mb/Sec
Minimum Fibre Upload Speed is 5.3 Mb/Sec
Maximum Fibre Upload Speed is 9.1 Mb/Sec
Minimum Guaranteed Download Speed is 22.80 Mb/Sec
13-06-2021 08:41 AM
Yes, you are not even getting the Guaranteed Min Speed.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
13-06-2021 09:00 AM - edited 13-06-2021 09:01 AM
We have another socket in the house that is connected to a phone. There are no wires on the back of the faceplate.
There was no noise on the QLT
Here are the router stats from the test socket:
13-06-2021 09:08 AM
If the extension socket is not connected to the master socket you might have "star-wiring" which could cause havoc with BB.
Do you use the extension phone? What type of master socket do you have? If you don't know, post a pic.
13-06-2021 09:14 AM
I'm not sure how the sockets are connected. I've disconneded the phone on the second socket since we never use it.
I've attached a photo of the master socket
13-06-2021 09:28 AM
Now the full router stats with the phone disconnected?
It won't be the phone that is the problem but the wiring to the extension socket. You might have sort that jumble of wires behind the master socket to eliminate the extension.
13-06-2021 09:31 AM
