20-05-2020 11:23 PM
I upgraded my phone on the 5th march in a we store for a pre order Samsung s20 ultra and have heard nothing at all since. My current phone battery is failing rapidly.
i know there is a pandemic going on but what’s annoying me is why haven’t I heard anything at all about my order
13-04-2020 08:54 PM
Hope.you both get the phone when it arrives, have a feeling that I won't get it tomorrow 🤨 definitely be weds 🤞🤞🤞🤞my memory cards been dispatched already 😃
13-04-2020 09:01 PM
@rhiang1984 no message yet?
13-04-2020 09:05 PM
No nothing as yet, but they said I will be able to track in the morning, so will be definitely be checking as of 8am 😃
13-04-2020 10:16 PM
Fingers crossed you'll get your message soon and your phone tomorrow. I've had my DPD message but at the same time an email from EE saying my Buds+ are now out of stock (what a surprise haha)
14-04-2020 01:32 AM - edited 14-04-2020 01:44 AM
@rhiang1984 sorry bro but please get a refund... I promise you those are fake of that's the exact seller you got it from. I've been using ebay for years and the price of those crys out fake especially when the seller is a new seller.
The evo micro sd card for a original and "real" evo card is between £75/£100... the cards will look same every way but if you do a check on your laptop you will find that the storage will be 20gb tops.
My advice to anybody getting micro sd cards online check on youtube for what to look for and also when a process is far to good to be true it's that way for a reason.
I hope I've caught you on time and this information helps you.
Ps anybody that is looking for compatible micro sd.....
Samsung Evo plus SDXC 512gb
Samsung Evo Select SDXC 512gb
Sandisk Extreme SDXC 512gb
Lexar 633x SDXC 512gb (cheapest option)
14-04-2020 09:31 AM
Had a email off eBay this morning about the items/seller and they removed it from eBay, if they are fake I definitely will do a refund as well not nice to messed about!
Thanks btw I shall list a few links later on to see if they are suitable!
14-04-2020 09:33 AM
I haven't had a email about the buds as I now decided to get them! 🤞 They be here soon enough 🙂
14-04-2020 10:52 AM
Some fake SD cards and storage, do show as the correct size by the system but are really small.
So if you try saving stuff to it, it will look like it's working, as if your getting the full storage but then when you try to access that stuff you will find out it's been overwritten in a loop to make it look like it's the full size.
14-04-2020 11:01 AM - edited 14-04-2020 11:03 AM
https://www.amazon.co.uk/dp/B07JGCKQD6/ref=cm_sw_r_other_apa_i_2OyLEb9Q7PX4B
@RE4PER is this a good one?
14-04-2020 11:07 AM
