02-11-2021 04:04 PM
media keeps pausing when using bluetooth. Checked all battery settings and app is set to not sleep etc. reset galaxy buds, reset galaxy s21, unpaired, repaired, updated, re-installed apps. still no luck.
02-11-2021 04:15 PM
Is this Music from your Storage, or Streaming Music (ie uses Data).
Which Music App you using.
02-11-2021 05:14 PM
Seems to be when streaming, happens on both wifi connection and when using mobile data.
I've tried Spotify, various radio player apps, and Soundcloud.
It still pauses even when the screen is unlocked.
02-11-2021 05:48 PM
Does it pulse and then start again or just stop.
03-11-2021 09:25 AM
It stops completely and I have to start it again. The earbuds remain connected as i can use them to start the audio again. (The issue also happens when connected to a bluetooth speaker)
03-11-2021 09:38 AM
Hi @Jonni101,
Do you see the same issue when using a wired headset?
03-11-2021 11:11 AM
03-11-2021 01:13 PM
03-11-2021 03:05 PM
It plays with no interruption through internal speakers with the screen locked or unlocked.
03-11-2021 03:07 PM
(No issues on calls via bluetooth, only media playback)
