For up-to-date information and comments, search the EE Community or start a new topic.  |
17-06-2021 01:01 PM
Hello!
I bought a SIM around a year and a half back but I haven't used it since.
Now when I tried to reuse it, the sim not provisioned message keeps popping up.
Can I not use the same number and would I need to get a new sim number?
17-06-2021 01:13 PM - edited 17-06-2021 01:14 PM
If you haven't used it for over 9 months it has been deactivated & you have lost it & its no. for good.
EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
17-06-2021 01:07 PM
I should also mention that I'm not in the country.
I'm in Tbilisi, Georgia.
I don't know if this is the reason.
