close
Payg SIM not provisioned
Rabz1234
Hi
i am currently abroad and haven’t used my payg sim for about 6 months. I am now getting the sim not provisioned message. I have tried to start a live chat to take the sim out of hibernation but cannot see the start a convo button. Any other way apart from calling from abroad?
thanks
@Rabz1234 : Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Northerner
Hi @Rabz1234
That message means your number is dead. It will be unlikely it can be recovered.
https://community.ee.co.uk/t5/Pay-as-you-go/What-is-pay-as-you-go-and-flex-hibernation-and-how-do-I-...
If you look in @XRaySpeX signature there is a free phone number you can try and maybe EE will be able to help.
Lastly if reactivated you may need to be on the EE UK network.
