17-06-2021 01:38 PM
Hi I need help sorting out my voicemail on my tablet
17-06-2021 01:40 PM
@Davidoff2224 It helps to say what the issue is.
17-06-2021 01:40 PM
17-06-2021 01:42 PM
I need help to activate it because it says the line is busy I am getting numbers phoning it and I can't get on my voicemail on my tablet to listen to it
17-06-2021 01:48 PM
@Davidoff2224 Can you text VM ON to 150 from your tablet. This will activate your voicemail.
17-06-2021 01:52 PM
It says hi we are having some trouble turning your voicemail divert on if you call customer services on 150 they will be happy to sort it out for you
17-06-2021 02:19 PM
@Davidoff2224 Try VOICEMAIL DIVERT ON to 150. If that doesn’t work you will need to call customer services
17-06-2021 02:33 PM
Ok thanks
