Re: No Service and Mobile Number now not recognised
KjbRB
Hi I am having the same problem i visited my local EE store they could not help rang EE again today told me to try a top up but even that would not work even though i have registered my sim details are not recognised
@KjbRB : Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
