Pixel 2 fingerprint and pin issue
Badpianoplayer
Hi, when trying to wake up my phone the fingerprint is not being recognised so then I try my pin.  It then either won't recognise that I have entered the pin or says "wrong pin".  I have tried to swap from a pin to a pattern but same issue.  Some days I have to restart the phone up to 12 times before it lets me in so now I have no fingerprint sign in which has disabled many features.  Any views on if this can be fixed or is it dead?
James_B
EE Community Manager
Hi @Badpianoplayer,
Have you tried removing then re-adding your fingerprints?
Badpianoplayer
Yes but now it won't let me re add my fingerprints because it's unable to accept the backup of pin or pattern etc
James_B
Hi @Badpianoplayer,
Are you locked out of your phone completely?
No as I disabled all of the log in security ie phone is completely unlocked all the time
Christopher_G
It may be worth backing up your phone and restoring it to factory settings, @Badpianoplayer.
