close
Pin not sent for eSim
botonakis
Valued Contributor
Valued Contributor
Hello all,
Through myEE app I chose the option to get the eSim
Everything seems to be OK until the step for the activation, when I have to receive a one time pin that I get an error that can't be sent
Any ideas? I can receive texts and messages with no problem ,I have checked
Thank you in advance ☺
botonakis
Valued Contributor
Valued Contributor
Hello again,
So it seems there is a known issue with the eSim activation from the app , as I was told from 150.
The agent told me to use the web version of myEE and it worked.
A tip may be that you may have to restart phone twice, as upon activation the data connection plays funny.
Thank you for helping
@botonakis   You’ll will have call customer services tomorrow morning about this.  This public forum doesn’t have access to your EE account.
botonakis
Valued Contributor
Valued Contributor
Hello Chris,
Thank you for this
I will do 🙂
botonakis
Valued Contributor
Valued Contributor
Hello again,
Jon_K
Former EE Employee
Thanks for letting us know you got this sorted, @botonakis 🙂
Hopefully other users can follow your advice if they experience this too.
Jon
