close
Phone won’t connect
Dp01
I have a iPhone se, it won’t connect to the wifi and it has 3 bars and is saying 4g but isn’t properly connecting to my mobile data. Have tried everything
10 REPLIES 10
Which are you trying to do, connect to WiFi or connect to mobile data? You can't do both at once.
Yeah I know I can’t do not at the same time, I have tried to do both separately and it’s not working. I put the Wi-Fi password in and the Wi-Fi sign flicks on then goes straight back off. I know it’s not a Wi-Fi issue as everyone else in the house is connected. Then with the mobile data it is just not connected properly every now and then I will have a pile of watts apps and messengers through then I can’t send any back
Tell the phone to Forget the WiFi connection & then connect to it afresh.
What's the source of your WiFi?
I’ve done that it’s not working
Leanne_T
Hi there @Dp01
Thanks for posting on the community.
Have you tried resetting your network settings, to do this go into Settings > General > Reset > Reset Network Settings?
This will remove any saved WiFi passwords.
Yeah I’ve done that as well
Leanne_T
Thanks @Dp01
Have you tried backing up your data and factory resetting your iPhone?
No I haven’t that yet was hoping I wouldn’t have to  but can’t think what else I can do
Leanne_T
It does seem like you have tried most steps @Dp01
Can you disconnect all other devices and see if the iPhone connects to WiFi?
