close
Packet Loss!
LiamEE
Valued Contributor
Valued Contributor
I’m suffering from packet loss on my connection, especially for gaming, the overall connection is in perfect condition, Speed, Web browsing, Streaming! I know my stuff when it comes to Network things. I’ve tried almost everything I can do, Can you guys help me or will I need to phone up support? As the issue lies outside of my house/control.
Thank you
7 REPLIES 7
Run a tracert to your gaming server.
LiamEE
Valued Contributor
Valued Contributor
I was thinking ping plotter as well? As I’m not familiar with either can you tell me what to look out for?
Thanks!
LiamEE
Valued Contributor
Valued Contributor
Done a ping plotter test and no packet loss on the router etc, however I do have 75% packet loss on an IP address 213.121.98.137 I’ve looked this up up and it’s showing a BT IP address?
pip11
Scholarly Contributor
If the packets were lost at that hop, how did they get to the destination?
When using ping plotter, tracert or any other always start from the destination and work back. All you are seeing is a router that has not responded to the icmp (ping) request in the requested time. Routers will always treat icmp requests as low priority.
Post the results.
LiamEE
Valued Contributor
Valued Contributor
I believe the issue is now resolved, It was a hardware issue with the Xbox, I forgot I sighed up to ‘Xbox insider' and opted in for the early release updates for the console and they contain bugs so I’ve opted out and removed the console from the program and now the packet loss and gone! 😉
thanks all for the help
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
