Not getting my minimum broadband speed
Adam_Hawley1997
Hi, I recently joined EE a month or two ago. The rated minimum speed that I was quoted is 38mbs. However after multiple tests I have done over a wired connection. The maximum speed that I am getting is around 22mbs. Please can anyone help.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
