close
No mobile data
VP21
Mobile data started to go off a few days ago but would come back on after a soft restart, now since then it's gone off all together, tried everything from turning airplane mode on and switching phone off then turning on after a couple of minutes to going into ee app and turning the content lock on, reboot phone, turn it off.
Still no joy!
Phone is a
Huawei i30pro 😭😭😭😭😭😭
Please help!! 🙏🏼🙏🏼🙏🏼
7 REPLIES 7
@VP21  take the Sim card out and give it a clean with a damp cloth now make sure it’s dry before you put it back into the device and test.
Jon_K
Former EE Employee
Hi @VP21.
I see you've had some great advice already, let us know how you get on with that.
Do you get a 4G symbol in the top corner of your phone?
Jon
mikeliuk
Hi @VP21 ,
Can you still make and receive calls, and send and receive text messages?
VP21
Hi mate, no I don't get a 4g signal and it greys out the mobile data button in the settings, had a update for my phone yesterday and that fixed the issue for a few hours but since then it just keeps going off
No I can't make calls, msgs or go online without wifi
Hi, this works as only a temporary fix.
Christopher_G
Hi @VP21
Are there any maintenance works in your area? You can check the network status on our coverage checker online.
