27-05-2020 10:14 AM
When trying to get an access code for my discount my ee login details are not recognised, I tried resetting my password it makes no difference. The login works when signing into my account normally. Is there any other way I can access the code.....
27-05-2020 12:27 PM - edited 27-05-2020 12:28 PM
Hi @Lorraine76
You may have used different log in details for your EE Perk account, this would have needed your work email address.
Have you tried logging into the EE Perk account with your work email and password you would have set at the time you registered?
You can select forgotten password and get an email to reset this if needed 🙂
Thanks.
27-05-2020 01:59 PM
Thank you Leanne for getting back to me. I’ve tried everything...nothing works. I also set up a new perks account and had a verification email sent to my email and still it wouldn’t validate the login details
27-05-2020 02:05 PM
Hi @Lorraine76
Thanks for the quick reply.
Did you receive the verification email?
What error message do you get when you try and log in?
27-05-2020 02:59 PM
Yes I got the verification email but when I tried to log in it said I had either an incorrect email or password
27-05-2020 03:03 PM
Hi @Lorraine76
Did you register with your work email address or personal email?
Have you tried the forgotten details option?
27-05-2020 03:34 PM
Tried both my personal and work email, have done the forgotten password, it didn’t work. I’m wondering maybe if it could be because when I registered last time I worked for a different nhs trust and had a different email that I can no longer access. If this is the case is there anyway I can update my details....
27-05-2020 04:08 PM
Hi @Lorraine76
I have sent you a private message on here for some details.
Speak to you soon 🙂
07-08-2021 02:11 PM
That’s exactly the problem I am having, tried both personal and works email and it didn’t recognise also tried to reset and again that didn’t recognise .
08-08-2021 07:55 AM
Hi @Tanyab1
I hope you're well and having a nice weekend, are you up to much or having a chilled one?
Can I just check, when you originally registered did you verify your email via a link we sent?
