close
New phone won't access EE mobile data
Alistair75
Yesterday I upgraded my Samsung Galaxy A70 for a Galaxy S20 FE.  I took the SIM card from the A70 and put it in the S20 FE, updated all the software, used Smart Switch to copy all my data from the old phone.  I have a 10GB data allowance, currently at 9.9GB to last 27 days.  If I switch off WiFi on my phone, or leave the house I can't connect to the internet and I am invited to sign in to the EE network.  This gives me the option of buying more data, although it'll helpfully point out I still have data left.
I've tried;
  • restarting the phone
  • switching airplane mode on and off
  • taking out the SIM card and wiping it with a soft cloth
None of this works.  I've not had much joy getting through to Tech Support, so any help from here would be greatly appreciated.
So after a few hours running various tests and tweaks with tech support, I put a different SIM card in my phone, my my SIM card in another phone.  My SIM card has the same problem in any other phone, but my phone works perfectly with a different SIM card.
This morning, I'll be going to the EE shop to get a new SIM card.
11 REPLIES 11
Hi @Alistair75
Welcome to the community
Is mobile data enabled on the device?
It is, I should have mentioned I also tried switching that off and on again.
James_B
EE Community Manager
Hi @Alistair75,
Can you download your internet settings at setup-ee.wdsglobal.com/internet and let me know if that fixes the issue?
Hi James,
Sorry for the delayed response; it took me a while to find the correct format for my phone number (international number with a '+' at the start, so +4475xxxxxxxx) before I got the configuration message.  If anyone else attempts this fix, I'd also recommend you have a note of your phone's model number from the "About Phone" section of the Settings, and you're able to make a note of the PIN you'll receive.
Unfortunately, this fix didn't work for me.  Maybe it's a problem with selecting the phone model.  About Phone states the Model name as "Galaxy S20 FE" and the Model number is "SM-G780F/DS".  I installed the file for "Galaxy S20 FE (SM-G780F)", restarted my phone and encountered the same issue.  I also installed "Galaxy S20 FE (SM-G780F DSM)", restarted, but the problem persists.
Could this be a fault with my phone?
Hi @Alistair75
Thanks for trying everything you have so far.
I would like to try something else. Could you go to network settings and change it to 3g wait for a little while then move up to 4g.
Please let me know if this helps.
Hello,
Thanks for the suggestion; I set the Network mode to 3G/2G (auto connect) and restarted.  An hour later I switched back to 4G/3G/2G (auto connect) and restarted.  No luck, I'm afraid.  I could repeat this using 3G only mode before resetting to 4G/3G/2G (auto connect), but at the moment the problem is persisting.
>An update
I switched to 3G only mode, restarted, waited 20 minutes and switched back to 4G/3G/2G (auto connect), restarted.  No change.
Thanks for trying that @Alistair75.
The best thing to do at this stage is contact our customer care team so they can look into this with you.
They'll do everything they can to get this sorted for you.
Thanks for your help, and the contact details.
No problem at at @Alistair75.
Please come back and let us know how you get on.
