close
How do I locate a lost Android mobile phone? Service provider is EE.
Chendry
I have misplaced my mobile phone. How can I find it? Does EE provide a locator tool for android phone?
Hi @Chendry
Have you tried calling the phone to see if you hear the ringtone? Assuming it has signal and the ringer is enabled, that's the easiest way.
Your alternative option is to use the Google locate service, at https://www.google.com/android/find  - this will only work if the location-based services are enabled on the device and active.
@Chendry  Sorry to say EE doesn’t provide anything for such issues.
try THIS, I hope it helps.
