05-07-2021 01:22 PM
So Here is the story. I currently own a Nighthawk X6 running though a BT openreach ECI B-Focus V2 Modem. MY ISP is EE
This has been working very well apart from having to use extenders in certain areas, so I wanted to eliminate this and purchased the Orbi
So I downloaded the App and proceeded to start the installation. Everything was going well until I got to the stage where the network was detected (which is was).
The app then told me it was checking cables and couldn't connect and asked me to go to advanced start up, where I needed to tell the app that I was connecting via PPP0E
I put the EE ISP user name and password into the app and it then went back to checking cables after it told me it was changing connection and going to produce some magic. It didn't.
What happened next was that a page telling me to go to setting and log in to the orbi wifi appeared. Sure enough in the connections on my phone there was the Orbi Wifi icon and when I touched it it changed to sign in required and then up came this service message from BT Wholesale
| SERVICE INFORMATION | |
You have been connected to this page due to one of the following reasons. You must now shut down your internet browser and internet applications before attempting to reconnect. This may clear the issue immediately, if not then please select the appropriate action from list below.
Numerous reboots, leaving everything off for 5 minutes or more and I was getting exactly the same.
So I then on the advice of a Netgear Community member I hard wired MY PC to the router and connected via orbilogin.net.
During the process the service message came up again, but I managed finally to get to the dashboard, where I attempted to set up the internet, again inputting the EE ISP user name and password.
After updating the settings the dashboard appeared again and in the Internet Box was the message 'Waiting' which soon turned red and stated Not connected.
So then began my five hours on the Netgear chat support getting disconnected twice and finally talk to Support on the phone, where once again we went through numerous reboots of every part of the system, looked at the firmware which was fine, checked the Vlan Bridge box and updated again all to no avail.
At the end of the conversation It was suggested that i contact EE and ask them to supply a different user name and password which I did, and was told by EE that they only had one for me which was the one I had already got. (I suspected this might be the case)
So here I am one very frustrated individual with a very expensive plastic box that for some reason does not want to communicate with my modem.
Putting my Nighthawk back on to the modem and everything is fine again
Anyone else experience anything like this with the Orbi/BT Modem/EE
05-07-2021 04:20 PM - edited 05-07-2021 04:22 PM
There should be an @FS (lower case but it's not letting me) at the end of the BB Username, but not the pwd.
05-07-2021 04:25 PM
Wow
i have just checked the user name that's in the dashboard for the nighthawk and you are spot on. You may well have just solved the issue. I will let you know later when I try it out
Annoyingly I phoned EE to ask for the username and password and they never mentioned it
Later!!
05-07-2021 04:27 PM - edited 05-07-2021 04:30 PM
It will 🙂 ! All EE BB Usernames must end in '@FS'. That's why you can't use other ISP's routers on it.
05-07-2021 06:08 PM
Thank you so much for your help. Simple solution but you were the only person to ask exactly how my user name and password looked. hats of to you
05-07-2021 07:50 PM
Well, your problem could only be the form of your BB Username.
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
