close
NEW SIM activation problem
JaneWatcham
Hello!
I went on activate my new sim and forgot to enter the activation pin I had received on the old phone. It said an error had occurred, and now when I try again, I'm not receiving my activation pin my on old phone to activate new one as the old sim has been disconnected already..... and the pin previously received doesn't work... can you help please?
Profile closed
Not applicable
@JaneWatcham if you call freephone 0800 956 3146 a tech advisor will be able to get your new sim up & running 🙂
Profile closed
Not applicable
Hi @JaneWatcham
Welcome to the EE Community,
If your old sim been disconnected already has the new one got signal ?
Thanks,
David.
Hi thanks for your help, old one has no signal, neither has the new one....
Profile closed
Not applicable
Done, they've sorted it out thanks! problem solved!
Profile closed
Not applicable
@JaneWatcham glad your all sorted if you need any further help in future visit us on the community 🙂
