close
My internet connection keeps dropping. Working from home for 111… any ideas why?
Claire150367
Internet keeps dropping.. working from home for 111.. causing major problems… I have rebooted my router.. not any better
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
mikeliuk
Hi @Claire150367 ,
In addition to the above, does the situation still occur with a wired connection to the router instead of WiFi?
If you have two devices connected simultaneously (e.g. phone and laptop), do they drop simultaneously or does one keep a stable connection?
pip11
Scholarly Contributor
Most likely noise on your line. 17070 option 2, the line shoud be silent between announcements, best with corded phone you may get a dull background hum with cordless.
