close
My SIM card isn't working
PhoebeJane
I have had the same SIM card since I had it last year. Today my SIM card suddenly isn't working.  I have turned my phone on and off multiple times and it still isn't working.
Is there anything you can do to help this?
Phoebe
@PhoebeJane  first off does anyone else have an issue with EE that is with you as if they do it might be a network issue and which case you might want to have a look at THIS and use the check network status tab.
 If all is okay in your area and then you might need a replacement SIM card. Can you get one from an EE store (you’ll need ID) or by calling customer services you must make sure you request a replacement SIM card.
James_B
EE Community Manager
Hi @PhoebeJane,
Are you using a pay as you go or pay monthly plan?
julia1954
can you send me a replacemnt sim card for the same no
Katie_J
Hi @julia1954
Please visit this page if you would like to order a replacement SIM.
There is a link at the bottom for you to order online.
Katie 🙂
