24-09-2021 09:38 PM
I need to unlock my sim card with the PUK code. I have found the code but it is only 7 digits long and the phone login says it needs to be 8 digits long and won't unlock my phone. What do I do?
24-09-2021 09:54 PM
@juliafarino You’ll find your PUK code within your EE online account. Where did you find “this” code
24-09-2021 10:49 PM
I called EE Technical Support and they gave me the number. It is also the same number that is on my Account when I log into EE. It is only 7 digits long but in order to unlock my SIM card, I am asked to enter an 8 digit number.
25-09-2021 08:54 AM - edited 25-09-2021 08:54 AM
Hi @juliafarino
Thanks for posting.
What is the exact message showing on your phone?
Thanks 🙂
25-09-2021
06:54 PM
- last edited on
27-09-2021
07:44 AM
DanielPA
It asks me to enter the PUK code saying that my SIM is locked. After I enter the 7 digit code it goes blank again and asks for 8 digits.
If I add a zero in front of the number, it accepts the 8 digits then asks for me to enter a new PIN number, I enter 4 digits, it asks me then to confirm the new PIN. I enter the new PIN number again and press the return button to enter. It then flashes up very quickly "incorrect PUK number" which the disappears and it then takes me back to beginning of the process asking me to enter my PUK number and tells me how many chances I have left which is now down to 5 remaining attempts.....
I would have thought that EE tech support would know how to make the 7 digit number acceptable when I called them but they didn't, so I thought I'd see if anyone in the community had had this happen to them and had found a way round it.
Thanks for you help.
x x x x x x x x x x x
[mod edit: please do not post personal information on the public board. Thanks!]
26-09-2021 08:05 AM
Hi @juliafarino
Thanks for coming back to me.
Can I just check does the message show as PUK1 or PUK2?
Speak soon 🙂
26-09-2021 08:01 PM
Hi Leanne
It doesn't say either PUK1 or PUK2 just PUK.
"Enter PUK code (Remains: 4)
"SIM CARD IS PUK-LOCKED - EMERGENCY CALLS ONLY"
After I enter my PUK code of only 7 digits, the message "Input 8 digits" comes up in place of the message that said "Enter PUK code (Remains:4).
27-09-2021 07:14 AM
Thanks for coming back to me @juliafarino
I've sent you a private message for some extra details.
Leanne 🙂
