close
Mobile data isn’t working
Paatric
Hi, I’m new to EE. My mobile data stopped working after my number was transferred to EE.
I’ve been without mobile data for 4 days now
10 REPLIES 10
Si_84
Hi
this is also happening to my phone, I changed my number on Tuesday and since then I can only get 3G.
This is a known issue with EE and they don’t know when this will be fixed. I’ve been refunded my entire months mobile / Apple Watch plan.
Northerner
Hi @Paatric
Try downloading your internet settings from here:
https://setup-ee.wdsglobal.com/index.html
I have an iPhone and it’s not on the list.
tmobilefan
  try  opening  up   " gov.uk "  web page or  " nhs.uk "  if this pages  opening  then   EE
have applied  a Data cap   you  will find  that when you call you be  lest with  only  front line   call operator who will to manage  to call by leaving you on hold  for  long time  only to   back to the call to say  we have  run check ,  every thing is  working  fine ,  if you ask to be  transferred  to  Technical  yo  will told  i'm very sorry   but they wont take calls
here is the problem if your tied in to a contract you   stuck  if you  on pay as you  go  the only  option  is  add more credit  .....
Christopher_G
Hi @Paatric
Welcome to the community.
Is there a carrier update available? Tap Settings > General > About. It'll pop up here if there is one.
Hi @Christopher_G,
I’ve followed the steps but I can’t see an update available.
Jon_K
Former EE Employee
Hi @Paatric.
If you can't see an update, it sounds like you're already up to date.
Are you able to try resetting your network settings?
This can be done in Settings, General, Reset, then Reset Network Settings.
Jon
I’m not sure what’s happened but my mobile data is now working.
I guess the issue must’ve been resolved.
Thanks for your help!
tmobilefan
hi there,
that is fanatic news to hear,
 i like to take credit   really  you my friend  you need to take the credit  for a
"  job well done"   in  fixing the   phone
OIP.jfif
 only a post away should you, get over welled with  technology   feel free to click the thumbs up  button in the  future
