close
Mini WiFi. Changed PW. Want to change Key
Tinkkisses
Hi
i have changed the password on my WiFi mini ( the under the battery cover password). But really wanted to change the WiFi key to something easier to remember. How do I do that?  Step by step instructions required as very not techy
thanks
T xx
I presume you mean you've changed your router's admin pwd. Login to your MBB router at http://192.168.1.1 with this admin password & look under the Wireless Settings tab. There you should be able to see your WiFi pwd in clear & change it.
13 REPLIES 13
Leanne_T
Morning @Tinkkisses
Thanks for coming to the community 🙂
Have you been able to change the password following @XRaySpeX advice?
Thanks 🙂
Yes, thank you the advice was spot on
Leanne_T
Brilliant @Tinkkisses
Thanks for coming back and letting us know 🙂
Have a lovely Saturday.
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
I have the same problem. The solution doesn't work because the original key (password) is deemed incorrect. It is correct because I use it to connect to the box. What's the solution? Thanks.
What is the answer? I have the same issue as I wish to change my password to someting I can remember.
@Carlo60 : Factory reset the router & the WiFi pwd will return to its default.
How do you mean by a correct pwd is deemed incorrect? By what?
Well, @Carlo60 , which is it to be? A mobile router or a Home BB router? You've posted to both.
