03-07-2020 04:25 PM
Hi
i have changed the password on my WiFi mini ( the under the battery cover password). But really wanted to change the WiFi key to something easier to remember. How do I do that? Step by step instructions required as very not techy
thanks
T xx
07-08-2020 11:59 PM
it's a mini router. And the mistake is mine. I didn't notice there is both a "key" and a "password." When I said it works, I meant using the key connected me to WiFi. I used the password to get to the 192.168.1.1 and make changes.
Sorry for the confusion on my part. And thanks,
Charles
08-08-2020 01:33 AM
@Carlo60 : "Key" and "Password" are used interchangeably for the WiFi security code.
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
15-08-2020 09:14 AM
I can't change password either. Msge says password (inside cover) is incorrect. I'm new to this forum and can't work out how to see replies to the same query other people have asked about. Can anyone help? Thank you T
15-08-2020 10:45 AM
Morning @TrishVB
Thanks for coming here.
Have you changed the password previously?
If not, have you tried using admin as the password?
