close
Join ee with previous network
fay2020
How can I transfer my number on ee from another network?
@fay2020   You have to request from that other network your PAC code you then give that code to EE.   You can request this via calling you that network customer services or by texting PAC to 65075 from that network SIM card.
Once I get that code what is the process after that
(i want pay as you go sim)
peterkinxl5
Dead easy,
First you must activate your new SIM. go to EE.co.uk and search for SIM activation .
After thats sorted, then go back  to EE.co.uk, search for 'How do I transfer my number?'   follow the instructions enter the code and it'll be transferred over within 24hrs.
