01-12-2020 10:14 AM
01-12-2020 11:18 AM
Hi @pinkdodo
I'm not clear from your post whether you're reporting poor coverage in this area, or a sudden drop in service.
If you're reporting a coverage problem, have you checked the network coverage to see what is predicted for this area? It sounds like you're already aware of the WiFi calling service, which can be very useful anywhere that indoor coverage is a problem for whatever reason.
If you're reporting a short-term or sudden loss of coverage, I'd recommend using the faults & status checker , which also includes the facility to report issues and get updates on existing ones.
01-12-2020 11:52 AM
01-12-2020 12:46 PM
If toggling or amending phone settings is having this effect, then it's either purely coincidental, or your phone has a fault.
Does your phone show signal bars when you have problems using it?
And can you make & receive voice calls when your mobile data doesn't work?
01-12-2020 01:37 PM
01-12-2020 03:04 PM - edited 01-12-2020 03:05 PM
What does the network coverage checker predict for your parents' home?
I included a link to the coverage checker in my second post of this thread.
01-12-2020 05:51 PM
02-12-2020 08:54 AM
Hi @pinkdodo.
Do you know of any other EE users who are able to use data in this area?
Has this always happened, or just started recently?
Jon
02-12-2020 10:33 AM
02-12-2020 12:55 PM
Thanks @pinkdodo.
I'd recommend getting in touch with our Tech Gurus about this.
They will be able to investigate further for you and help you get to the bottom of this.
Jon
