close
If I upgraded and received a new SIM do I need to swap sims or if the same size
gingerob
If I upgraded and received a new SIM do I need to swap sims or if the same size can I carry on using my current SIM?
FYI I went from a Huawei P20 Lite to an Oppo A72
You may continue using your old SIM.
Leanne_T
Hi there @gingerob
If the SIM is the same size, you can use your old SIM card.
If not, you can register your new SIM at myaccount.ee.co.uk/app/activate-sim and keep the same number 🙂
Thanks 🙂
