Community Activity
EE/BT Blocking access to mail.micloud19.com
Hi,  I have called in a few times to try and get this resolved, to no avail.I can not access my work emails (outlook) on my home computer with EE as a provider.  It gets immediately blocked and says to check the proxy and firewall settings.   The onl...
Gill98 by Investigator
  • 197 Views
  • 19 replies
  • 3 Helpful
EE wifi hasnt worked since we switched
when we switched we have been promised multiple different speeds all over 20mb/s. we also got promised a smooth easy transfer from our previous wifi company. since we switched the wifi has not worked at all we have been lucky to even get 10mb/s and t...
Sjmh by Visitor
  • 2 Views
  • 1 replies
  • 0 Helpful
EE wifi Hotspot
I have recently subscribed to EE broadband and have noticed that my router is broadcasting " EE wifi" . I would like to remove this facility but there doesn't appear to be any way ....can someone help? Thanks
Data roaming
Do I  get charged only for the days I use the daily roaming service
PAC53 by Explorer
  • 18 Views
  • 2 replies
  • 0 Helpful
Apple desktop not connecting to Apple email
My Apple desktop iMac stopped connecting to Apple Email, on 22nd June.But my iPad and Laptop do connect.However, Apple have looked into this (extensively), and say it is a network issue, not an Apple Mail issue, as they found other problems with my c...
