close
Home broadband
Sanina123
Home broadband is very slow
Miss s bibi
@Sanina123  Have you tried restarting the router? Turn off for 30+ seconds and then restart it and try again.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Yes it’s abit now working fast again than you
Miss s bibi
Leanne_T
Thanks @Sanina123
Glad to hear this, if you need any further help, please let us know 🙂
Thank you
Miss s bibi
