For up-to-date information and comments, search the EE Community or start a new topic.  |
13-10-2021 01:15 PM
I am trying to get my broadband checked as it is cutting out throughout the day, however I keep getting directed to a bot to look at it, which requires my landline number. I am on a “broadband no landline” package so I’m stuck! Any idea how I can get help?
13-10-2021 01:58 PM
Does this bot ask for any other identifiers, like ALID, BBEU or UPRN? These you can get by asking CS.
13-10-2021 02:00 PM
