close
Help!!! Broadband
bugbear19-68
Only had EE broadband a month promised the world on how good it is,, internet keeps dropping & buffering when watching you tube & netflix,, checked everything seems to be running fine with all the checks & tips,, really considering going back with sky! They said they will credit me with £100 to pay EE would I b still charged extra with leaving early please can anyone help!!!
@bugbear19-68 : Welcome to EE's Home Broadband Forum.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Hi I'm not sure as I'm not very techno,the lights are still green as far as I know,, i don't have anything to plug the grey wire in as I have no laptop or computer, it just seems to be buffering all the time,,,I had no problems when I was sky!! My spped test is saying 24.95,, is that good ?
Which router do you have?
Nobody can say your speed is good or bad w/out knowing more about your line, which I asked you for. Everyone's different!
It ok I've been on phone to ee thanks for your help though
