close
Fttp on fibre 36
Vicgurt
I've recently upgraded to fibre 36 from standard and my Internet drops on the regular and kicks everybody off the network. Part of the deal is we get FTTP, if fibre runs thru the street then to our property on the standard line instead of of a new fibre line would that cause a problem with the Internet?
Thanks in advance
85 REPLIES 85
Vicgurt
There's a problem somewhere on  the line, Internet stopped working a few times today. I just thought that going from FTTP to FTTC may have caused the problem.
You didn't go from FTTP to FTTC. I thought you went from standard ADSL to FTTC?
Post your full router stats:
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Vicgurt
I get a little mixed up sometimes with adsl, fttp, FTTC but I have an Xboxone connected by ethenet everything else wireless and we all connections to WiFi but no Internet can't remember lights on hub tbh but I'll get stats now 2 min
Vicgurt
I forgot to say Ive been using a bt smart hub instead of the EE hub as it seems to stay online longer so I have to swap the boxes over now
Vicgurt
EE Smart Hub ManageradvancedPage
Technical log
InformationEvent logThis is a list of your EE Smart Hub settings and current statistics.
Product name:Smart Hub
Serial number:+EEH001+1912003009
Firmware version:v0.06.01.08190-EE
Firmware Updated:Sun Dec 13 00:25:27 2020
Board version:01
DSL uptime:0 Days, 0 Hours, 7 Mins, 22 Secs
Data rate:10.00 Mbps / 40.00 Mbps
Maximum Data rate:27.86 Mbps / 71.10 Mbps
Noise margin (up/down):17.7 / 15.1
Line attenuation (up/down):14.9 / 12.6
Signal attenuation (up/down):15.1 / 12.6
Data sent / received:72.0 MB / 1.7 GB
Broadband username:PRODUCTIONHQNUN@fs
2.4 GHz wireless network name:EE-Hub-qM
2.4 GHz wireless channel:Smart (Channel 6)
5 GHz wireless network name:EE-Hub-qM
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:64:CC:22:4D:F4:76
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
Vicgurt
@XRaySpeX  are three them?
Technical log
Board version:01
2.4 GHz wireless network name:EE-Hub-z9qM
5 GHz wireless network name:EE-Hub-z9qM
Firewall:Default
Software variant:-
Vicgurt
Technical log
Board version:01
Broadband
Firewall:Default
Software variant:-
@Vicgurt wrote:
It wont let me post my credentials on the page
Use the Camera icon above your text to upload an image file to here.
Vicgurt
Vicgurt
