04-11-2021 12:12 PM - edited 04-11-2021 12:19 PM
Hello all
I've been advised our Fibre contract will renew this month but will change from £24.14 to £32.14 a month. This is a 30% increase which seems steep. We're EE mobile customers too, with 4 devices and we've been customers for years.
And our fibre speed is only 18Mbps?? Is it worth it?
Any advice greatly appreciated.
Thankyou.
04-11-2021 12:21 PM
If you ring CS you should be able to negotiate a new discounted rate - doing nothing just means you move to the undiscounted rate. Along with many services these days it is worth looking around at what you could get the service for elsewhere before the call.
04-11-2021 01:10 PM
Have you reached the end of your min. contract term? Your bill will increase at that time as you would've been informed when you took it out. You can see this even now with EE's current offers:
Fibre Plus Broadband
- 54-73 Mb/s estimated download speed range
- £27 a month, 24 month contract, then £32 a month
Which EE BB package do you have?
Instead of letting your current contract run on at the higher price, all you have to do is commit to a new 24-month contract for the same BB package at a lower price than you are paying now. You can do this online thro' your MyEE for BB under Change your broadband plan .
04-11-2021 01:11 PM
04-11-2021 01:37 PM - edited 04-11-2021 01:41 PM
Thanks XraySpex.
My log details are as follows.
Product name:Smart Hub
Serial number:+EEH001+1837000566
Firmware version:v0.06.01.08190-EE
Firmware updated:Wed Dec 16 00:54:24 2020
Board version:01
DSL uptime:5 Days, 13 Hours, 48 Mins, 59 Secs
Data rate:2.74 Mbps / 18.00 Mbps
Maximum data rate:2.68 Mbps / 21.75 Mbps
Noise margin (up/down):6.1 / 9.8
Line attenuation (up/down):36.6 / 29.0
Signal attenuation (up/down):36.2 / 24.2
Data sent / received:6.0 GB / 66.8 GB
Broadband username:
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:
5 GHz wireless channel:Smart (Channel 44)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:4C:1B:86:C0:91:19
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017
04-11-2021 01:43 PM - edited 04-11-2021 01:44 PM
@ralphster Posting your router stats isn’t going to solve anything. It sounds like you’re reach your minimum contract period which means any discount you had are removed as you’re out of contract. You need to be in contract to have a reduced bill. Your contract has reverted back to its original contract price that’s all.
I don’t know why you’ve been asked to post them in the first place you don’t have a connection issue.
04-11-2021 01:45 PM
Thanks Chris_B, I may be able to renew at a lower rate however, I'm sure the speed has dropped over time and I wanted to confirm I wasn't paying for a lesser service.
04-11-2021 01:47 PM
@ralphster It’s not dropped at all. You’re probably find it because you have get so used to it and it starts to seem slow from when you first had it because when you first got it it probably felt quite quick .
04-11-2021 02:25 PM
@ralphster : I would say you are getting slower than expected speeds. Now let's see your BT Wholesale Broadband Availability Checker estimates.
@Chris_B : I asked the OP for his router stats & more as he implied in his OP that he was not happy with his speeds as well as the price increase. So don't take it out on the OP when you can't possibly know what's on my mind!
04-11-2021 03:16 PM
| 26.8 | 17.6 | 3.7 | 2.2 | 15 | Available | Available | -- |
| 26.3 | 15 | 3.7 | 1.9 | 11.4 | Available | Available | -- |
| 330 | 50 | -- | Available | -- |
| Up to 6.5 | -- | 5.5 to 7.5 | Available | -- |
| Up to 6.5 | Up to 1 | 5.5 to 7.5 | Available | -- |
| 2 | -- | -- | Available | -- |
| Up to 6.5 | -- | 5.5 to 7.5 | -- | -- |
| Up to 2 | -- | 5.5 to 7.5 | -- | -- |
| 17.99 |
| 3.05 |
| 2021-03-09 |
| Available |
| Available |
| U |
| N |
| N |
| 28-10-2021 |
| N |
| N |
| Y |
