close
EE Broadband slower when plugged into the master socket
Profile closed
Not applicable
Hi there, I recently moved house. When I was temporarily setting my networking stuff up I decided to use the extension in my living room. After moving stuff etc I plugged my stuff into the master socket...the speed has dropped?
I assume it will go back up but I was just wondering if this was normal?
Thanks all
Profile closed
Not applicable
Well I found the problem...the wiring is an absolute joke. Openreach's wire coming from outside doesn't reach the socket properly so the wires had to be extended using splicer joins. There were joins upon joins to the socket. Hence the drop in speed....
9 REPLIES 9
No it's not normal in a correctly wired home. Post your full router stats from each socket.
Profile closed
Not applicable
This is from the extension socket
Uptime 11 hours 17 minutes
 UpstreamDownstream
Current Rate (kbps)1188779998
Max Rate (kbps)1188782559
SNR Margin (dB)6.15.4
Line Attenuation (dB)29.514.5
Errors (pkts)186612925
This is from the master socket
uptime 23 hours 27 minutes
 UpstreamDownstream
Current Rate (kbps)1122360386
Max Rate (kbps)1122361835
SNR Margin (dB)6.14.2
Line Attenuation (dB)33.614.7
Errors (pkts)14821
That shouldn't be. Do you know how the extension is connected to the master? Are you sure the extension is really a slave? Can you post pix of them with faceplates removed?
Profile closed
Not applicable
Pictures don't seem to work. They show a blue exclamation mark
They are awaiting approval. Post them again & I will do so.
Profile closed
Not applicable
There are no face plates per-say. There is a master socket in the hallway that my equipment is currently connected to. On the other side of that wall is that second socket with the extension from the third picture connected to that.
Pretty odd setup to be honest.
  1. Middle pic: Can you undo the screws to reveal the box behind?
  2. L pic is a OR NTE5C Mk4 Master socket. Going by Linebox NTE5C User instructions please reveal the back plate (2nd or 3rd pic) & back of filtered front cover (last pic on L).
Profile closed
Not applicable
Well done!
