| For up-to-date information and comments, search the EE Community or start a new topic. |
18-10-2021 08:52 PM
About 10 days ago approximately, out of the blue my EE suddenly started going incredibly slowly at random intervals. Streaming Netflix, YouTube, video conferencing, online gaming - even just loading webpages - would all suddenly become really slow. Then, a while later it would seem to sort itself out. This has continued ever since.
There's no obvious pattern - it's not that at certain times of the day it's slowing down...or when I'm doing a particular thing with the broadband it slows down. It just seems random - these periods of 'lag' do seem to getting more frequent, and last longer - and conversely the periods of stability seem to be getting less frequent and shorter.
Just a few extra bits of info:
Today I ran the BTW Performance tester at random intervals and recorded the results:
| Time | Ping | DL | UL |
| 1202 | 293 | 2.37 | 1.03 |
| 1203 | 378 | 2.34 | 0.99 |
| 1204 | 435 | 2.59 | 7.42 |
| 1230 | 430 | 4.06 | 4.22 |
| 1231 | 372 | 4.22 | 1.14 |
| 1232 | 437 | 3.32 | 0.99 |
| 1257 | 14 | 29.14 | 6.63 |
| 1258 | 14 | 26.96 | 6.79 |
| 1259 | 14 | 28.5 | 7.27 |
| 1338 | 98 | 25.99 | 3.78 |
| 1339 | 137 | 22.46 | 3.47 |
| 1340 | 149 | 26.32 | 4.07 |
| 1522 | 89 | 20.55 | 6.68 |
| 1523 | 117 | 21.93 | 4.05 |
| 1524 | 136 | 17.64 | 2.79 |
| 1626 | 150 | 29.31 | 3.91 |
| 1649 | 134 | 20.04 | 2.39 |
| 1650 | 149 | 23.48 | 3.73 |
| 1821 | 128 | 20.63 | 7.27 |
| 1822 | 130 | 18.04 | 1.6 |
| 1823 | 89 | 27.72 | 2.22 |
| 2023 | 425 | 2.9 | 0.99 |
| 2026 | 425 | 5.6 | 1.56 |
| 2031 | 362 | 2.77 | 2.72 |
As you can see - only around 1257hours was I getting about what I should be getting. The rest of the day any time I ran the test I wasn't getting what I'm meant to be.
https://www.thinkbroadband.com/speedtest
http://www.broadbandchecker.btwholesale.com/#/ADSL/AddressFeatureProduct
| 65 | 47.7 | 13.3 | 8.5 | 41.6 | Available | Available |
| 62.7 | 41.8 | 12.9 | 7.5 | 35 | Available | Available |
| 330 | 50 | -- | Available | -- |
| Up to 17 | -- | 10 to 19.5 | Available |
| Up to 17 | Up to 1.5 | 10 to 19.5 | Available |
| Up to 7.5 | -- | 6.5 to 8 | Available |
| 2 | -- | -- | Available |
| Available |
| Available |
| N |
| N |
| Y |
I spoke with EE on the phone again today and they are sending a 'Cube' engineer out Thursday morning - in honesty I don't really know what that means.
My wife relies on fast, stable internet for her work - what else can I do in the meantime to fix this? I'm pulling my hair out here.
18-10-2021 10:22 PM
19-10-2021 08:41 AM
http://www.thinkbroadband.com/speedtest/1634628908646664255
| Available |
| Available |
| N |
| N |
| Y |
Thanks for your time and prompt reply.
19-10-2021 10:29 AM
Um,, Connection speeds are good but Upstream speedtest extremely slow & downstream TBB speedtest fairly slow.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & speedtest when plugged into test socket.
Is the issue any better?
