close
Very slow connection when using PC with EE fibre 150mbps
Uzer13
Hi.
I have had EE Fibre broadband for ages now without any issues, its mostly fast and reliable (unless im using my pc)
I bought a new gaming pc. And if i run a speed test i see speeds as low as 4 mbps.
I run my ps4 test it was 85mbps.
So im getting completely different results at different times no matter what speedtest i do.
i was using BT wholesale test as that is the reccomended one by EE.
By the way all my devices use ethernet cable except things like my tablet and phone.
Also does anyone know if its cheaper to not have a land line with packages like fibre 150mbps if thats even possible?
I have the openreach socket installed and a 6 port ethernet switch if that makes any difference.
do i need the adsl switch on my phone jack or not?
if this carries on and i need a engineer to come out will i have to pay for it?
I mean if theres advertised speeds on one device and not on another why is this?
thanks
LP
Fibre w/out landline (number) is always possible & is £2 pm cheaper.
What do you mean by an ADSL Switch? Even Fibre Max 150 is DSL.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
hi i have used a function on my pc called dual boost which uses wifi and ethernet simultaneously and uplugged the filter as it wasnt necessary.
im getting a steady 120mbps on bt speedtest.
im wondering if its time dependent because my connection was terrible earlier trying to download an tarkov update
thanks for your help and i will check now and then see if everrything is ok
Hi @Uzer13 ,
At the time when you see bad 4 Mbps measured bandwidth, do fast.com and speedtest.net agree the measured bandwidth is bad? When you see bad download speeds, I think it's worth running a simultaneous fast.com test to see if the issue might be on the remote server side.
Having an additional unnecessary filter when there is one built-in to your master socket won't cause any harm and could be added back in if you see errors or indications the data line is unclean.
It would only be useful to use WiFi and Ethernet simultaneously if combining them exceeds the performance of the wired Ethernet connection alone, otherwise you are causing your PC to perform some degree of switching. WiFi is half duplex so you would additionally introduce latency issues, on top of CPU switching, as compared to a wired connection.
