Downstream sync speed constantly deteriorating
youface
I am on EE fibre max 300 for many years now but recently the speeds have been dropping. the latency has been high especially in games and my internet connection has been dropping every night for a few mins literally every night or every other night.
The downstream sync rate dipped below 180 so an openreach engineer came to my house a few weeks ago and checked for any faults internally/externally and he couldn't find any major faults. He put the sync rate back to 320 ish as he said my line can handle a max of 330. The sync rate again is dropping, please see the screenshots. The sync rate has gone down to 250 on bt line check when few weeks ago it was at 290-300 ish. I am sick of this constantly happening because again im not getting minimum guranteed speeds of around 230. Also this new smart hub is so stupid how you can't make 2 seperate SSID for 5ghz and 2.4ghz because there is no way to filter which connections you want on 5ghz and 2.4ghz.
Any help would be appreciated
17 REPLIES 17
From the BTw Checker post the line at the top of the table showing your exchange & cab. but obscure your phone no.
youface
The broadband drops, not just wifi but ethernet + wifi drops, when I go onto the smart hub page it says no broadband connection or cable not connected then it connects after a few mins, the smart hub flashes green.
There's cabs 5 all over the place. Where's the exchange?
youface
I have updated the screenshot, cab 5 CHORLTON
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
youface
my fibre 300max package does not include a landline, we agreed to have it removed when discussing the deal months ago, will that still affect me being able to call from the landline?
If you bought EE Fibre w/out landline no. you can't make landline calls & it hampers the diagnostics we can do on your line. But then why are you giving the BTw Checker a phone no. & it is showing 1? You sure about that?
youface
Showing 193 downstream
Downstream speed going down too, each night internet goes off for a few minutes and then the downstream rate goes down further, last night it went down to 155mbps ish.
Nothing new there then! Sorry, we can't proceed further w/out checking for noise with the QLT.
