close
Do i need an engineer visit
An31
I have a engineer coming tomorrow to install my fiber but I'm not sure I need one as I all ready have fiber through ee and only upgraded
10 REPLIES 10
Normally you would not need an engineer unless you were upgrading from FTTC to FTTP. What EE fibre products are you moving between?
I'm currently on fibre plus moving to fibre 100
Is Fibre Max 100 being delivered as G.Fast or FTTP? Is a FTTP ONT being installed at your home? If so an eng will be needed.
An31
All the plan says is it fibre max 100
pip11
Scholarly Contributor
Well fibre max can be delivered in two ways, either by FTTC or FTTP. If via FTTP an engineer will be needed.
Get back and let us know what happens,
Mustrum
@An31  If you were to enter your phone number into the BTW DSL Checker it would show if G Fast or FTTP were available and would know what the engineer would be doing.
@pip11 wrote:
Well fibre max can be delivered in two ways, either by FTTC G.Fast or FTTP. If via FTTP an engineer will be needed.
pip11
@XRaySpeX   You should have corrected my post as well as I stated (incorrectly) FTTC as well.😂
On a slight technacality though. How is G.Fast delivered to the cabinet? Is that not by FTTC?🤣
@pip11 : Eh? I did & I don't!
