close
Connect my samsung active 2 4g watch to plan
Anthk87
I bought the active 2 4g watch direct from Samsung.
Am i able to use/connect the data from my EE monthly phone contract?
I tried using instructions but it times out when searching and suggests asking network provider.
Thanks.
@Anthk87   Once it’s been set up to your phone you should be able to set up a new separate Sim only tariff for your watch this will be £7 a month and you will get 10 gig of data. You do this via the wear app.
 You can not use your phone data allowance for the watch as the watch is a separate device that you want to add to your account and that will need it’s own data connection. If your having issues with this I recommend a call to EE customer services.
