10-09-2021 05:53 PM
I have a home broadband internet account with EE. I have a 4GEE-router-Q57Z (Model B625-261). It is a 100GB account.
I also have a Samsung SM-J330FN smart phone. This smart phone now has no account associated with it, as i didnt use it for a long time. So i cant use the smart phone. When i used it i was with o2.
Now i wonder if i can use the sim card in my EE router with my Samsung smart phone?
I need this as i now need to do zoom meetings when i am out on the road.
(Incidentally, i also have a small "bar of soap" size mobile phone which is on a EE pay as you go account. I wish to keep this phone as its nice and small and easy to carry about, so its my main phone)
10-09-2021 06:20 PM
Hi @treez
So long as the SIM will physically fit, you can use it in whatever device you choose. From a quick Google search, the router uses a Nano-size SIM, the Samsung J3 is a micro-size, so you'll need an adapter of some kind.
If the phone is locked to O2, then you will only be able to use an O2 SIM with it - or will need to get it unlocked to accept a non-O2 SIM.
10-09-2021 06:26 PM
Thankyou.
I think my wifi sim has different sim card sizes within it......is it ok to just turn off the router and take out the sim card so i can check it to see if it can be adjusted to a micro size sim card...or can this damage the router?
Also, do you know where i can go to get the smartphone unlocked from O2, so i can get EE service instead using my wifi account?
11-09-2021 07:50 AM
Hi @treez
I hope you're well and having a nice weekend, are you up to much?
You can take the SIM out without damaging the router, that's not an issue.
To get the O2 phone unlocked you'll need to have a chat with O2.
11-09-2021 10:45 AM
Thanks, i guess to get unlocked from 02 i have to go in to an 02 shop?
I guess they arent going to be too receptive to the idea.
Is there no place i can email to get it unlocked over the web?
Another option is to look into buying an EE smartphone...........but they never seem to do "pick up from store", and i am always out at work when they come to deliver.
Presumably i can just buy an ee smartphone that uses the same size sim card as the one in my router, and then i can use that smartphone.?.....Also presumably EE wont send me a duplicate sim card so that i can just leave the sim card permanently in my wifi router...and also have one in an EE smartphone?
In all this i am assuming that since i pay monthly for a ee wifi account (with a "mobile router") , that i wouldnt need to pay any more to extend this to a smartphone aswell?
11-09-2021 10:57 AM
Hi @treez
I'm not sure how O2 work when it comes to unlocking, however you should be able to request this no problem.
We can't send a replica SIM I'm afraid.
If you would like a phone from us then you can pop into one of our stores and they'll look into your options.
11-09-2021 11:06 AM
Thanks,
Sorry to keep asking.
If i order an EE smartphone over the web, (hopefully then pick it up from an EE shop on the weekend?) then presumably i dont have to pay any more money for the useage?, as i am already with "EE wifi mobile router"?
11-09-2021 11:09 AM
@treez If you order a pay as you go phone then no, you'll only pay more if you sign up to a new contact.
11-09-2021 11:11 AM
Thanks,
So i guess what i want is to buy an EE smart phone, but without a contract (and nto pay as you go either)...then just keep taking the sim card out of my EE wifi router and putting it into the ee smartphone?
11-09-2021 11:14 AM
