close
Can a 'Data Only' SIM receive phone calls - for use in electric gate
reg228
The situation:
My electric gate has a PAYG EE SIM card with £10 credit which gets deactivated every 6 months because it has no 'activity' i.e. outgoing calls or texts. Apparently there are not enough numbers to leave 'inactive' SIM cards live (which I fully understand BTW)
I'm told by EE to put it in a phone every 6 months and send a text to keep it active.
My question:
If I were to purchase a 'data only' SIM, would it be able to receive incoming phone calls to activate the GSM module on my gate?
TIA
EssexBoyEE
Your going to have the same problem if it's a PAYG Prepaid Data SIM, once activated it will have the usual limited Life Span if it's not used for a while with an Outgoing Chargable Cost.
Yes, data SIMs are able to make & receive calls & texts. It's just that making calls & texts are not included in any allowances & so have to be paid for.
