close
Re: Cant topup or call 150
Zain14
I use my phone it has been only a couple of days I cannot receive any calls I have tried evrything
13 REPLIES 13
@Zain14 : When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
I want to top it up but I cannot call 150 or any number to top it up with and voicemail asks for some pin setup
@XRaySpeX  when I call 150 it straight away cuts off
@Zain14 : If you were to answer my Q we may be able to tell why this is happening.
Along time ago I haven’t used it but only recently was I not able to receive calls anymore @XRaySpeX
Well, it must have gone into hibernation as I told you earlier.
How do I take it out @XRaySpeX
@Zain14 : If you read my 1st post to you it'll tell you.
Depends when you last used it for a chargeable action:
  1. Over 9 months: you can't.
  2. Over 6 months: by calling CS.
What number do I call to contact ee and if it’s an option one what option do I click @XRaySpeX
Call CS on the Freephone no. in my sig.
