close
Broadband nightmares
JonnyTomato
Broadband has been terrible. Regularly restart the box which sometimes helps. We often end up using our neighbours wifi. Have been miss sold faster broadband which has consistently slower than before. Was told by the shop it would only be £2 more a month. The online team say they cant help. The shop team say that they also can't help. The EE website is also not very good to find out how to fix my problem.
Mustrum
What problems are you having?
Is it the broadband or just the wifi?
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
