| For up-to-date information and comments, search the EE Community or start a new topic. |
22-05-2021 08:40 AM
I have been having issues with my broadband since I joined EE almost 2 years ago. I recently booked an engineer appointment and took the day off work, waited at home with my then-five month old son, and no engineer arrived. Furthermore, I had no contact regarding the appointment.
A woman in my local store said I’d receive a new appointment or compensation regarding this, though I’ve yet to receive either. I’ve tried contacting about it online, to no success as obviously there’s no live chat for anything other than upgrades. Also, the website doesn’t allow complaints to be sent. How do I get clarification regarding this?
Furthermore, am I right in believing that, as my issue of significantly lower broadband speed than my minimum guaranteed has not been resolved, termination charges are removed should I switch to another provider? I don’t want to, as I usually love EE’s services, but this has been a very disappointing and frustrating experience. I work from home and my broadband cuts out every day.
22-05-2021 10:45 AM
Welcome to the community, I'm sorry to hear about your engineer visit and speed problems.
Have you spoken to our broadband technical team over the phone? They should be able to look into why the engineer appointment didn't go ahead and help with your speeds.
22-05-2021 11:21 AM - edited 22-05-2021 11:22 AM
You need to give EE the opportunity to get your speeds up above the guaranteed min. before you may leave FoC, but they don't seem to be taking you up on that.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
