close
Broadband connection issues
Kinners5915
Has none else with EE broadband been having terrible connection issues lately?
Router is showing as green, connected, but none of the devices my house have a connection strong enough to load anything.
Is EE aware of this?  What are they doing about it?
Why am I paying for a service I'm not getting!
BB issues are not usually widespread or even localised. The issue will be with your own specific line or even just within your premises.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
